Anybody ever try to use a newer engine family in a P1800?
Maybe a B230 from a 240??
P1800 engine retro-fit
kmvandewater
- Year and Model: 2011 XC60
Kyle
1961 PV544
2011 XC60
1961 PV544
2011 XC60
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Yes: B230FT into 1800...kmvandewater wrote:Anybody ever try to use a newer engine family in a P1800?
INSTALLING A B21/23 IN AN 1800
1800 TECH INFORMATION
If B230 is placed vertically, I think some engine modification is in order; like the Oil Pump setup for sure.
Funkymohawk27
- Year and Model: 1997 850awd sport wa
I have seen an engine from a 240 in a 1800 as well as a 740 turbo engine in a 1800.
sorry I can't give you any details as to modification specifications. but yes it can be done
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I believe there was one year only (early 240) where Volvo used a B12 "tilted" engine mated to an M40 or M41. If you could find one of those bell housings you could probably succeed in swapping in a B21/B23/B230 family of engine. A B200 16 valve turbo like they used in Europe would be a cool deal.
It's not totally impossible to take a bell housing from a B20/M40 or M41 car, cut the bell housing into two pieces, clock it the proper number of degrees, and weld it back together. But you would need to cut it in the right place and you would have to jig-up some sort of fancy tooling so that everything is properly aligned when done.
- 683 Views
Last post by NC2001v70
- 662 Views
Last post by ragged
- 1806 Views
Last post by raivis_rsn
- 722 Views
Last post by simi1665
- 716 Views
Last post by MoVolvos
