Hi all
I will be finishing up some work on the front end and need to know specs for:
*hub to steering knuckle bolts
*outer tie rod end to knuckle
*lower ball joint to steering knuckle
*CV halfshaft to hub
*Strut mount to steering knuckle
I think that is it... if anybody has those numbers I would be very grateful!
Thanks in advance!
2001 S60 2.4t Torque specs
the65dartguy1
- Year and Model: 2001 S60 2.4T
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Here you go, all Nm and degrees:
1- control arm ball joint to hub: 50 + 35 deg
2 - drive shaft: 35 + 90 deg
3 - strut to hub: 105 + 90 deg
4 - tie-rod end, AL hub: 50 + 40 deg - steel hub: 70
5 - if "hub to steering knuckle" are the 4 bolts that secure bearing housing to hub: 20 + 65 + 60 deg
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
- 1745 Views
Last post by kosh_al
- 3568 Views
Last post by gibbi42
- 7552 Views
Last post by miticavolvo
- 683 Views
Last post by williala
- 1492 Views
Last post by 2forty
