1995 850 glt instrument cluster
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
IIRC, there are 2 different kinds of instrument clusters for the 850. So long as the make is the same, they fill swap just fine. Remember, there are turbo and non turbo clusters. While a turbo will work in a non turbo, the boost gauge will not work unless you hook it up to a vacuum line. But what is wrong with yours? A new ODO gear is only $10, and a few light bulbs are reasonably cheap.
The problem with a swap is the miles on the ODO. Legally, the ODO cannot be lower than the miles on your current cluster. The A-7 port will show you the miles.
Klaus
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Apart from turbo and non turbo clusters,which only difference is in turbo gauge,for non turbo models there are Yazaki and Vdo clusters.
They are visually very different,so as long as replacement cluster looks just like yours it will fit.Cars with Yazaki clusters are very rare and chances that you will find one are pretty minimal.
So...you can put instrument cluster from '97 to your '95.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 4918 Views
Last post by oragex
- 4433 Views
Last post by polskamafia mjl
- 2005 Views
Last post by jrob0201
- 723 Views
Last post by camjohns
- 1602 Views
Last post by erikv11
