19xx. p80 ECT measurement temperature vs resistance
Has thanked: 1610 times
Been thanked: 4068 times
Courtesy of Mike (precopster)
As these 3 items closely determine coolant temperature they should be OEM. The temp switch may be out of range and can be tested in a pot of water. Here's a table of correct values for the temp switch
0 degrees - 5740 Ohms
10 degrees - 3700 Ohms
20 degrees - 2450 Ohms
40 degrees - 1150 Ohms
80 degrees - 318 Ohms
100 degrees- 184 Ohms
