My 850 turbo otherwise is running great but after it has warmed up, for example after I have driven and the freeway and then come to a stop at a light, the RPMS will drop sometimes, and sometimes the car will stall. This will happen intermittently. If I keep my foot on the throttle a little bit I can prevent the rpm drop and stall. After the stall, it will start back up pretty rough but then it will stabilized until the next stop. I don't have any codes.
Last week I replaced the cap, rotor, and wires (spark plugs had been changed 10k miles earlier) and I thought that had fixed the problem but then it returned yesterday when the weather got into the 80s again. I tried unplugging the MAF but the car ran worse and stalled. Yesterday I replaced the IAC valve but doesn't seem to have helped either. Not sure what else to do at this point. My next moves were going to be to clean the throttle body and replace the fuel filter. Anything else I should be looking at? Thanks.
1996 Volvo 850 Turbo Rough Idle and Stalling When Warm
I had a very similar problem on a S60 and turned out to be MAF going bad, the car acted weird and had different symptoms but would always lead to jumping RPM and eventually stalling
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
jonesboy1983
- Year and Model: V70 2007
Looks like it was the fuel filter. I also had some pretty nasty vacuum lines going to the TCV but the fuel filter looked like the original with the masking tape on it and car has not had any stalling or rough idle issues in 2 weeks since I replaced.
- 7659 Views
Last post by enriquepr21
- 17 Replies
- 4777 Views
Last post by 850corb
- 3513 Views
Last post by mazzaw12
- 1217 Views
Last post by Jonboy74
- 61 Replies
- 11699 Views
Last post by balzybenzy
