IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
FINALLY, a Vacuum Hose Diagram Topic is solved
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Re: FINALLY, a Vacuum Hose Diagram
Post by Juan62 »
IS THIS CORRECT: from the first pic above for a 98 S70 T-5M? On my T5-M is follows: (base on this diagram)
Red hose #20 insert into #1 (hole) and TCV red mark.
Blue hose from TCV blue mark, insert to MAF (Turbo Inlet Tube).
Yellow hose is correct: [ #19 wastegate, insert to TCV yellow mark].
98 S70 T5-M Brick for life
rcannon
Year and Model: 96,7 850 T, GLT Wgns
Post by rcannon »
Juan62- the green hose in the first diagram from the parts book is actually the red hose on the hood circuit diagram blown up several places above.
i.e. (per my 96 850 Turbo,)
#17 green is the red hose in the diagram going to TCV top position. The hose has a green stripe on it.
The blue hose #18 is a vent line and attaches to the inlet air line just above the TCV.
Hose #20, the red hose in the parts book is the bypass hose in the diagram. This yellow striped hose goes to the front, into the inlet manifold pointing directly forward, next to a larger rubber hose, both next to the throttle control.
manovlov
Has thanked: 128 times
Been thanked: 15 times
Post by manovlov »
Hy everyone,
Since few time, I use to smell gasoline around my car, especially on the driver side, outside.
My car is a 850 GLT wagon 2.0 20 valves non turbo - 1995.
May someone could help me to find fuel hoses diagram for my engine ?
I may have plugged something wrong, and count on the diagram to follow all hoses and replace the bad ones
Thanks a lot
Manovlov
Vroum !
Auburn T5
Year and Model: 1999 S70 T5
Post by Auburn T5 »
How much of these vacuum diagrams apply to the 99? We've still got our 99 T5 and I'm doing more stage zero work and replacing all the vac lines.
Edit: My google-fu is strong this morning.
Here's the diagram for the 99+ guys in case a google search led you here.
2016 VW Golf R - 6 speed manual - all stock... for now...
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
Year and Model: 2004 V70 2.5T
Been thanked: 158 times
Post by cn90 »
Question for turbo guru:
I have a 1998 S70 GLT, re diagram for turbo vacuum and cooler hoses: is it the same as the pictures posted by "MadeinJapan" for T5 model.
In other words, T5 vs GLT diagram, are they the same?
Year and Model: 850, S/V70, 06 S60R
Has thanked: 117 times
Been thanked: 336 times
Post by erikv11 »
I am not a turbo guru but: yes, they are the same.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
Post by erikv11 »
Here is a routing diagram for a 96 non-turbo:
'96 855 NA, 145k
'06 S60 R, 167k
instarx
Year and Model: V70 XC SE, 2000
Re:
Post by instarx »
Ghassan wrote:hi,
Can someone point out what the mini air filter is for. There is a large one on the left side of the screen (I believe for air intake) and there a small one on the bottom right side of the picture. What is the small one for?
thanks.
ghassan.
I believe that is part of the air pollution system. The canister contains activated charcoal that adsorbs fuel vapor from the gas tank when the engine is not running. When the engine is first started air is pulled back through the canister via the vacuum system and the fuel vapor collected is burned in the engine. That filter is to clean the small amount of air that flows into the charcoal canister.
2017 Alfa Romeo Giulia Q2 - if I could marry this car and have car babies with it I would!
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 387 times
Been thanked: 1221 times
Old, old thread alert. One good thing about it was that one of the vacuum diagrams actually corrseponds to my 1999 T5 - the actual sticker under the hood is an 850 diagram.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
gmullen
Year and Model: 1998 V70 T5
Post by gmullen »
Could use some help with anyone with some input. I just did a PCV repair job and need help getting my vac lines back in the correct place. The problem is the diagram on my hood and in this forum do not seem to match reality. Take a look at the pictures below. The diagram where the red star is shows only two line there going into the manifold. One is the fuel return and the other comes off a check valve that goes to the purge valve. But where does the third one go to with the yellow star in the second picture?
1998 V70 T5
