960 throttle body parts
am rebuilding a 960 throttle body to use on a modded 98 LPT. there is an o-ring seal on the throttle blade shaft, under the return spring assembly not the green one under the throttle position sensor, that has become brittle. anyone know of a source for that o-ring? I have some part numbers from a Skandix diagram, 1014837 and 419568. not sure if correct or what a good source might be. any suggestions?
- 3323 Views
Last post by Sommerfeldt
- 1028 Views
Last post by smeha
- 734 Views
Last post by Matty Moo
- 492 Views
Last post by jimmy57
- 782 Views
Last post by MikeHotchkiss
