Hi All. This morning I started the vehicle and while waiting for it to rev down from the cold start i was looking at the instrument cluster (thinking how will i fix the dead fuel gauge backlight) and saw the check engine flash once and the engine kicked off the hi rev start.
I haven't yet scanned it, but the check engine light did not remain on at any point.
I suffer every time i start it and it goes to 15-1600 for about 30 seconds. I like to idle low for a bit to warm up..........
whatever it is... after fixing it, i could use the fault to stop the dreaded rev up without triggering a hard code... like putting a switch to the offending sensor to kick it to 500-600 idle...
Any body experienced this?
2004 xc90 T6 check engine light blinked once....
they are, but this rev up was interrupted a few seconds in. The check engine light blinked once and kicked the engine out of -cold start mode- to a regular warm engine idle speed.
123, 164, 245, 240, 740, 940, V70XC, S80T6, XC90T6 and a Toyota Prius to drive to the Volvo dealer or while waiting on parts for them....
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
THere is no way to keep it from this warm up, I believe is a CEM programming or similar.
As for the light, perhaps there was a momentary misfire
Scanned it and did not find anything related.
CAN error is my fault... Installed an interface to get audio, BT and HDRadio input in the factory stereo and didn't reset after unpluging fiber optic.
AQS is just too expensive to replace
- 6317 Views
- 4275 Views
Last post by chittychittybangbang
- 2809 Views
Last post by FLXC90
- 475 Views
Last post by Dieudonne
- 1166 Views
Last post by SSTurbo
