2001 S60 insturment cluster dead/ hvac dead
- phils94850
- Year and Model: 2009 s60 turbo
A friends car the insturment cluster is inop and now the heat and a/c controls is not working either. I checked all the fuses and they are good. I assume its a bad CEM ??
1996 Platinum Edition
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The a/c controls could be a fuse in central panel. This can fail when the battery is connected without having the ignition key in position II
The cluster can be repaired on Ebay for $150
- phils94850
Central panel is the fuses under the hood ?
- oragex
It's the part were the heating controls are located, above the shifter. There seems to be a small relay inside, there was a diy posted by someone with a similar issue.
- 6000 Views
Last post by RaynormusT
- 835 Views
Last post by regent
- 5012 Views
Last post by oragex
- 1499 Views
Last post by MDK
- 11 Replies
- 4383 Views
Last post by Faheyk1981
