2003 V70 High Beams will not stay on
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
chiefpontiac
Year and Model: V70, 2001
Post by chiefpontiac »
Need some help. I have a 2003 Volvo V70 and have a problem with the high beams staying on after actuating the level. I pull it towards me, the high beams come on and the indicator is illuminated on the dashboard. When I release the lever as you normally do, the high beams go out. No way to get them to stay on.
I have replaced the headlight switch, the high beam and low beam relays near the CEM . Nothing makes a difference.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Do you have the headlight switch turned on?????
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
Like JRL said make sure to check that the headlight switch is in vertical position, its a easy thing to miss as the headlight are always on.
My father had asked me the same question the other day
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
chiefpontiac
Holy crap......I chased down a low beam short for so long on this car that I recently bought, that I didn't see the forest through the trees when I finally fixed it. The headlight switch was in the off position (horizontal).......Thanks JRL and Vovo_merz for waking me up and not taking advantage of my lack of awareness! On to the PO133 code now....this car may pass inspection some day.
