Car has been been running great on an ARD Green Tune with boost consistent at 16 -17 psi. Two days ago I had a boost spike to about 22 psi, it was the first time I have had a boost spike running this tune. After that spike I am now only hitting 10psi at WOT. No smoke, nothing obviously wrong and the boost holds steady.
I swapped my TCV with a known good one, reset the ECU and there was no change. Still boosts only to 10 psi and holds there. I have no codes, I did not see any loose vacuum hoses (all are silicone) or charge/intercooler hoses (also silicone).
I rebuilt my 16t urbo under 1000 miles ago and installed a new CBV. After the rebuild the car ran great and always hit the targeted boost.
Any ideas?
98 V70 T5 Manual - Low boost on ARD Green Tune
- Year and Model: Many Volvos
- Been thanked: 76 times
Is the wastegate operating smoothly?
I would just move the rod with everything hooked up and see if it catches anywhere and make sure the spring pulls it back to all the way closed.
I would not touch that MAF if I were you. Its new. Don't want to damage it with chemicals
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I lost 3 psi from a slightly loose clamp. Triple check all the hoses.
I second, checking the waste gate action. The rod gets quite rusty and can restrict the movement. I lightly sanded it and put anti-seize to make the operation smoother.
I would also check that the CBV is working okay.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Seaway
- Year and Model: 1998 V70 T5 Manual
How do I pressure test the CBV? Just hook up a hose to the CBV and add pressure with a hand pump?mecheng wrote:I lost 3 psi from a slightly loose clamp. Triple check all the hoses.
- 1986 Views
Last post by bmdubya1198
- 1421 Views
Last post by matthew1
- 2197 Views
Last post by Grooveman221
- 11 Replies
- 3357 Views
Last post by MrAl
- 3096 Views
