So I picked up this '04 V70 T5, with 203,000 miles. Got it for basically salvage yard price, but the body is in immaculate condition, and it has brand new Michelins all the way around.
It has a cracked radiator, which is pretty straightforward. Just replace it. It also has a badly leaking head gasket - even pushing coolant outside the engine. I know it's possible that the head might be warped.
So I'm pondering replacing the head gasket - which is going to run me at least $350 - or trying to find a complete engine to install. Good used engines seem to run pretty close to $1,000 - give or take.
My question is this: My engine is a B5234T3. Serial #3167885. Can I use a 2.3 Turbo from other year models, or am I stuck finding one from a 2004 within this serial number range?
'04 V70 T5 Compatible Engines
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
If you do the labor yourself I'd attempt to fix current engine, at least pull head and measure block for warpage.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
JeffHicks
- Year and Model: 1989 240 Wagon,
I'm doing my own work, and am definitely wanting to just replace the head gasket if that is possible. But if not...draser wrote:If you do the labor yourself I'd attempt to fix current engine, at least pull head and measure block for warpage.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
precopster
- Year and Model: Lots
- Been thanked: 128 times
The 2003 plus cars have CVVT on both cams however I'm not aware of any changes up to 2009 on the S60s if they were a T5 model. (same engine)
- 2156 Views
Last post by Danius
- 14 Replies
- 1978 Views
- 1107 Views
Last post by SuperHerman
- 3042 Views
- 534 Views
