2000 S70 P1171 Code
agreenwo
Year and Model: S70 2000
Post by agreenwo »
Hello, I am new to this forum and recently aquired a 2000 S70 AWD Volvo, The car has had the emissions light on for approx a year. The code pulled indicates a P1171 DTC. Through internet researching I was going to pull and clean the MAF sensor but was told this could end up costing me $1200 and car might not run after the cleaning. I also found something that looks like a canister with hoses attached located under the rear portion of the car with tape holding one of the hoses on. This cannister looks hard to access, any help would be appreciated
DrJammer
Year and Model: 2000 V70XC - 195k
Has thanked: 1 time
Post by DrJammer »
You can always try cleaning the MAF with some MAF cleaner/spray first. You can search for that on here as well as other troubleshooting methods.
Changing the MAF should run you about 200-300 bucks. Get OEM ONLY for this part. Swapping should be pretty straight forward
Although from past readings the 1171 may refer to the canister purge valve (near your taped up area?) and the 1172 refers to MAF.
I would start with MAF spray and research replacing canister purge valve. I am not familiar with purge valve prices or procedures, doubt it is more than a MAF, but is likely harder to replace. also search this site.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
Has thanked: 1609 times
Been thanked: 4065 times
agreenwo wrote:Hello, I am new to this forum and recently aquired a 2000 S70 AWD Volvo, The car has had the emissions light on for approx a year. The code pulled indicates a P1171 DTC. Through internet researching I was going to pull and clean the MAF sensor but was told this could end up costing me $1200 and car might not run after the cleaning. I also found something that looks like a canister with hoses attached located under the rear portion of the car with tape holding one of the hoses on. This cannister looks hard to access, any help would be appreciated
The canister with the taped on hoses is probably the a EVAP container and will trip your engine light. You need to fix that, clear codes, and drive for a week to reset the monitors.
You can replace the MAF yourself in about 15 minutes. Bosch only.
agreenwo
Post by agreenwo »
Thanks a lot for reply's. I did a bit more snooping under the hood and found most vacuum hoses are in poor shape, the device attached to the side of the air box right near the MAF has cracked. A lot of these hoses look almost impossible to get to to replace, also noticed the head gasket appears to be weeping oil a bit. Thanks again
