1997 850 Base - Fog Relay for driver's rear brake light
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Not sure if the issue is relay failure, b/c new bulb, still the driver's side rear brake light doesn't work.
It's the same side where fog light is located.
Any pointers?
xHeart
Post by xHeart »
My search points to PN 9128814 Lamp Control Failure Sensor.
Ozark Lee points to the blue box located under the trunk carpet, behind the driver's rear light.
Item #2 in this diagram http://volvopartslisle.com/assembly/25529899/Other-Relays
xHeart
Post by xHeart »
Can his controller be tested with multimeter?
1997 850 Lamp Control
xHeart
Post by xHeart »
Pin numbers printed on relay housing.
3 x Stoplight is likely 54H (high-mounted) R for right and L for left, is it?
pin numbers
pin numbers
