Evening all,
All topics covering replacing the timing belt and setting the time say that the camshafts sprockets marks should line up with the belt cover notches and the crank shaft notch (notches in my case) should line up with the mark on the block.
I have spun the motor around six or so times and when the cam marks line up with the cover, then the crank shaft is one full tooth past the mark on the block.
Am I missing something?
Thank you,
Alex
98 v70xc timing belt issue
Ludermilch
- Year and Model: 98V70XC 98V70R 01C70
- Has thanked: 1 time
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
2001 C70
1998 V70R
- Year and Model: Many Volvos
- Been thanked: 76 times
Not really. It is possible that it has been one tooth off for a long time. The car will still run and actually run OK at one tooth off but it will run better when they are lined up.
Ludermilch
I do thank you for that information. Now on to making my wagon even better.
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Pretty common issue. Make it better.
Ludermilch
Thanks to a video of yours that is what I am attempting. You had installed NA cams in the Give Away Volvo, I said to my self "You can do that?!" and since I really needed to fix a leak in the cam cover I picked up a set and am making it better. Now I am glad I took on this task and found another thing that neeeded correcting.rspi wrote:Pretty common issue. Make it better.
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
Ludermilch
Quick update to what I accomplished. After putting in the new cams and triple checking the timing..... I am proud to say that the car runs smoother and with more pep than before.
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
My son's '96 came to me like that as well so it really isn't as uncommon as you might think. It made a difference but, unfortunately for him, it didn't turn the car into a turbo.
- Has thanked: 311 times
- Been thanked: 817 times
Well, at least it already had NA cams!!
michaelk1960
- Year and Model: 2000 Volvo C70
I change my Head gasket set the timing but on attempting to start my 2000 C70 it will not start, there is no compression, any suggestions?
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
michaelk1960 wrote:I change my Head gasket set the timing but on attempting to start my 2000 C70 it will not start, there is no compression, any suggestions?
2 questions...
Why post in this seemingly unrelated thread?
Do all 5 cylinders show no compression? If so, your cams are way out of time, and you should pull the head back off to get it set right or you could damage valves (unless that already happened!)
'00 S70, '04 S60 and the never ending quest for Stage Zero
- 5228 Views
Last post by jimmy57
- 23 Replies
- 17044 Views
Last post by jonesg
- 20 Replies
- 17352 Views
Last post by Hurtfeelings
- 28 Replies
- 5355 Views
Last post by Carboncopy
- 2492 Views
Last post by precopster
