2001 V70 sound in the first few meters after starting
theslashy
Year and Model: V70 2001
Post by theslashy »
Hi,
i'm quite new to volvos and just bought 2001 V70 with only 70000km.
Today i heard a little scratching sound from the front, when first starting, at 20-30km/h, just once.
When i stop and let the motor run und start driving again it does not reappear.
When i stop the motor start it again and start driving i can hear it again at about the same speed.
I searched around a bit and read that this should be the ABS Self-Test. Is this true? i didn't find much info on that....
thx in advance
JudgeRat
Year and Model: s60 2004
Has thanked: 3 times
Post by JudgeRat »
It is possibly the self-test; Volvos run a lot of self-tests right after starting: ABS, SRS, etc. Since you describe it as a scratching sound rather than a rapid rat-a-tat-tat or rattle sound though, it might be that you have a slightly warped brake disc or hanging brake caliper. I'd make sure you don't have any uneven wear on your brakes. If not, its probably just the self-test.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
zoli_m13
Year and Model: S60 2001
Has thanked: 1 time
Been thanked: 2 times
Post by zoli_m13 »
Guten Morgen, theslashy! :-)
I'm also new (S60) owner, but similar issue with me; may be your brake discs have shoulder (like my one's) and that's why the reason of noisy brake at the self-testing. Do you hear the same at hard braking?
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
This is ABS self-test. Car does it every time engine is started and car achieved 20 km/h.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
+1 on ABS self check. Posted the same question few years ago.
theslashy
Post by theslashy »
Thank you all for your replies, i'm pretty shure now it's only the self test.
The Disks and Brake-Pads are quite new, so i'm not worried anymore...
