BOSCH Alternator Voltage Regulator F00MA45207 30667899
purplecat001
Year and Model: 04 Volvo C70 Con LPT
Post by purplecat001 »
BOSCH Alternator Voltage Regulator F-00M-A45-207 / 30667899
$80 SHIPPED w/ USPS Priority Mail (within the 50 states)
This part was purchased brand new from a reputable European online store for my 2004 Volvo C70 2.4l alternator (Volvo alternator #9459077 / Bosch #0 124 515 019). It is a BOSCH Alternator Voltage Regulator F-00M-A45-207 / 30667899 which I installed to replace my original Bosch F 00M 145 352 / Volvo 9459746
part. I installed it for a test drive and realized it was not the issue. It was then uninstalled and re-boxed. I replaced all of the electrical cables and that solved my voltage drop issue. When I had it in for the test drive, I measured it directly with my multimeter and is was putting out the correct voltage so I know it works for sure. [Lesson learned- do not buy parts until you are SURE it is the problem]
For those who do not know: Bosch is the genuine OEM manufacturer for Volvo alternators.
Here are the interchange part numbers I know of, but check your voltage regulator to be sure.
Interchange part #'s: BOSCH F 00M A45 207; BOSCH F 00M 145 352; BOSCH F 00M 145 230; BOSCH F 00M 145 210; VOLVO 30667899; VOLVO 9459746
