Hi all. A month or two ago I bought a new (used) XC WAGON. I had a 2001 XC, this newer one is a 2004. I was very excited to find one with the low miles of 80,000. This one does not appear to have as much power as my 2001. Not only that, but when I accelerate at lower speeds, it sometimes feels like it pauses. Strangely, my husbands brand new ford explorer does the same thing. I am not sure if there is actually something wrong, or if I was just used to the power of my 2001.
Was/is there a difference between 2001 and 2004 re power and pickup?
2004 XC Wagon Car pausing when accerating
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I had this 'pause' when the spark plugs had the incorrect gap. I would pull them out and inspect the gap (not just replace them right away because this way is easy to spend too much money). I would then look at the fuel filter if yours has one (most models don't have a serviceable such filter).
And perhaps have an independent garage read the error codes. Be aware that with such older vehicle, visiting the main dealer can prove very expensive and not always efficient.
Also check to see if there is any air leakage between turbo charger and the throttle body, best way would be is to smoke the system, I had a small hole in one of the tubes and it was running great and was only noticeable under heavier acceleration
hope this helps
hope this helps
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
- 1234 Views
Last post by s2zeller
- 2165 Views
Last post by zoli_m13
- 8874 Views
- 1035 Views
Last post by precopster
- 6279 Views
Last post by waffleshill
