I'm not using the S70 as frequently but if the car is left for any period, such as 3-4 days, when I attempt to start the car, the start is very soft and a mushy feel to the ignition, while the idle hits 2-300 rpm, struggles, before climbing to 1000rpm, then sits at 800rpm (as it should).
Seconds later, if I then turn off the ignition and start the car, everything is perfect, fries up as it should and rpm straight to 800rpm.
Any idea of what could be causing this issue?
1998 s70 Mushy/Soft start, when car is left to sit
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I guess that battery is close to empty because the car is not driven frequently.After you start it and run for a while,battery gets a little of charge and that's why it starts normally afterwards.
These cars are known to eat batteries if not driven frequently.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Misha, maybe I didn't explain properly but when I start the car seconds later, I mean literally 2 seconds after the mushy/soft start.misha wrote:I guess that battery is close to empty because the car is not driven frequently.After you start it and run for a while,battery gets a little of charge and that's why it starts normally afterwards.
I guess it could be the battery but seems strange that the problem goes away if I turn the engine off (without running car) and fire it up within a couple of seconds.
- misha
I understand what you are saying.The only logical explanation is that.Do you have check engine light(lambda light) on?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
No,nothing! just me sitting there wondering if it will start!misha wrote:I understand what you are saying.The only logical explanation is that.Do you have check engine light(lambda light) on?
I was wondering if there are any parts which can cause issues if moisture/dirt etc builds up? or if its associated with the starter motor?
- misha
It's the battery...guaranteed.
Next time when the car sits for a few days...before you start the engine,open the hood,get a digital multimeter and check the battery voltage between terminals.
12.7v 100% charged
12.2v 50% charged
11.9v discharged (it will not even crank at this voltage)
Also try to prime the fuel pump a bit before starting.Turning the key from position I to position II about three times,one after another,will prime the fuel pump.On third prime start the car.If the struggle you have disappears...that's just because of sitting for a few days.
12.7v 100% charged
12.2v 50% charged
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
What is a mushy soft feel?
Is the engine sputtering and missing some cylinders?
850 T5-R '95 auto
Don't worry mate, its now hard and fasthausmeister wrote:What is a mushy soft feel?
- misha
I told you that i knew what you were talking about.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 827 Views
Last post by RickHaleParker
- 1281 Views
Last post by - Pete -
- 14 Replies
- 695 Views
Last post by volvolugnut
- 1020 Views
Last post by jennysass
- 380 Views
