Two separate incidents today. CEL and code P1017. I know the car needs an ETM. I suspect that's just confirmation.
Later the cooling fan continued to run after shut off after a 20 minute drive at 45 mph tops with ambient temperature of 65 degrees F. I' m guessing time for new ECT and thermostat. Thoughts?
I shut the fan off by pulling the corresponding fuse.
'99 S 70 P 1017 and running cooling fan after shut off
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Sounds like bad ect,but check the connector first.Instrument cluster gauge behaviour normal?No code?E Showell wrote:...Later the cooling fan continued to run after shut off after a 20 minute drive at 45 mph tops with ambient temperature of 65 degrees F. I' m guessing time for new ECT and thermostat. Thoughts?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I had same issue with the fan staying on, faulty ECT. Replaced it first with an aftermarket one (which turned out to be more expensive then a genuine one), the aftermarket one failed within 3 months. Replaced with a genuine one and been fine for 2 years and counting!E Showell wrote:Two separate incidents today. CEL and code P1017. I know the car needs an ETM. I suspect that's just confirmation.
- E Showell
Engine behavior was normal and no CEL associated with the running fan.
With the. P1017, the engine runs rough.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
Ha....mine is still original.Around 300k km and counting.Never had an issue with it.JRev wrote:...Replaced with a genuine one and been fine for 2 years and counting!
I think that scheduled change of Basf glysantine G48 every 3 years is keeping it in good condition and good working order.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Instrument cluster temperature gauge behaviour normal too?E Showell wrote:Engine behavior was normal and no CEL associated with the running fan.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Yes, instrument cluster gauge behavior is normal.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
Symptoms you have are pointing to bad ECT.Check it's connector before you order a new one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
So, new coolant, new thermostat, new ECT and still getting a PO1017 code. Any bright ideas?
'95 855 auto (sold)
'95 855 auto (sold)
- misha
Did you replaced ect with oem or aftermarket one?
If you replaced it with aftermarket,that's the reason why.
Also...thermostat temperature should be appropriate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2791 Views
Last post by OnTrack
- 681 Views
Last post by DGM
- 2764 Views
Last post by cleven
- 2786 Views
Last post by cmbfoto
- 15592 Views
Last post by FREEBUSINESSES
