1993 940 Air Bag Deployment, control module
anotherMattsDad
Year and Model: 1993, 940
Post by anotherMattsDad »
My sons done it again, blew the air bag, (fell asleep),he is ok, 2nd time, found a doner, have to swap air bag, clock spring and drivers seat belt, there was no passenger in vehicle.
3 questions:
Does the control module have to be replaced or can it be reset?
Will the pass seat belt have to be replaced?
What years will fit a 93 940 non turbo?
Thanks,
Rick
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
anotherMattsDad wrote:Does the control module
1993 940 non turbo SRS light
Electrical: SRS Air Bag and Seatbelts
93Regina
Post by 93Regina »
anotherMattsDad wrote:What years will fit a 93 940 non turbo?
Volvo 850 1993, 1994, 1995, 1996, 1997
Volvo 960 1994, 1995, 1996, 1997
Volvo S90 1997, 1998
Volvo V90 1997, 1998
93Regina
Post by 93Regina »
Need part number
bau321
Year and Model: s70 1998
Post by bau321 »
Wish I knew.. wondering myself how to reset the srs and how I can fix the seatbelts once replacing the airbag with one from the yard
93Regina
Post by 93Regina »
bau321 wrote:Wish I knew.. wondering myself
billofdurham [MVS Moderator] said:
1993+ 940s have an on-board diagnostic system for the Supplemental Restraint System that both monitors the system and stores any fault codes for later diagnosis. You can read and erase codes using the OBD box in the engine compartment.
Check out other URL: Electrical: SRS Air Bag and Seatbelts
anotherMattsDad
I finally have gotten the module p/n 0 285 001 042 (says 01) I'm assuming (there I go again), 1 air bag no pass bag,
Will a 0-285-001-040 (says 02) out of a 94 940 work since your only using 1 air bag.
Just for info, 1 person in vehicle, blew drivers airbag on impact (driver ok), minor damage to car, had to replace air bag. clock spring, both seat belts, and air bag module. All from the yard. Thank you (---- a p---)
For resetting the SRS module or reading codes see Bill Durhams earlier post in this forum
"1993 940 non turbo SRS light" or this from above:
Thanks again Bill
93Regina
Post by 93Regina »
anotherMattsDad wrote:Will a 0-285-001-040 (says 02) out of a 94 940 work since your only using 1 air bag.
Stock Code 271740 ; 6812956
Suppl. Restraint system (srs) 940 For vehicles without airbag on passenger side. For vehicles with airbag on the passenger side.
Volvo 940 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998
Volvo 940 SE 1991, 1992
Volvo 960 1991, 1992, 1993
