2000 V70R - AWD Rear sub-frame out. Pictures?
Has thanked: 2199 times
Been thanked: 1852 times
Now that I have pulled the sub-frame out from under the car, does anyone need any pictures of any particular parts of the assembly for reference?
Let me know if you need anything and I'll try to oblige with the relevant pictures.
2000 V70R AWD rear sub-frame
Blockpartie
Year and Model: ...
Post by Blockpartie »
I'd really appreciate some pictures of the fuel line routing. Especially in the area of the filter e.g. how the lines come around to and from the filter.
As a side note: Whoever installed your custom exhaust didn't think ahead. There should be a connection point near the shock tower to allow removal of the mid and rear exhaust section.
Actually there are 2 joins, one for the muffler to the 'Y' piece and one near/at the stock connector. Trouble was they are stuck together and with limited access of the sliding type connections and concern that I may shear the system, I decided to leave it until I have removed the fuel tank from the sub-frame and then dis-assemble if I can. I've also now considered leaving it as is and returning it that way as it sits perfectly on that side. I'll wait and see.
It will be a couple of days, but I'll get some photos for you and then let me know if you need more details in specific areas.
Hi Blockpartie, sorry for the delay, but had 8 winter tires to remove first. Took around 2 hours today taking reference photos and will start to upload as I have time (around 85 photos). I have photos of all the fuel pipes and routings, the emissions pipes (with the exception of the one from the front of the car as I had to remove it to get the sub-frame out), and also all the extra crap that Volvo has added in on this car for the header fuel tank, the multiple return pipes etc.
I am going to review the pictures now and look if I need to add to them. A quick scan shows I may have to do a few more reference photos of the area being reviewed.
