Hello someone probably has answered this question, but the forum is huge and i couldnt find answers to my questions.
I hawe got a Volvo C70 Cabrio 2001 2.0T Engine Code B5204T4
I hawe a problem with oil leakage for a while alredy and my B5204T4 Engine 2.0T with 163Hp has been working for alredy 600k kilomters so i decided to just replace the engine, found one used B5204T5 from an y.2005 S60, the question is will it fit, i searched google and both engines hawe the same parameters but i guess im too dumb or lazy to find out what exactly is the difference, is it just the turbo and ecu.
I found pictures of the T5 engine and visualy its identical, but im still not sure if the gearbox will fit.
Thank you for your help
The B5204T3 is a 2.0L (1,984 cc) straight-five. Bore is 81 mm (3.2 in) and stroke is 77 mm (3.0 in).225hp
The B5204T4 is a 2.0L (1,984 cc) straight-five. Bore is 81 mm (3.2 in) and stroke is 77 mm (3.0 in)160hp
The B5204T5 is a 2.0L (1,984 cc) straight-five. Bore is 81 mm (3.2 in) and stroke is 77 mm (3.0 in).180hp
2001 C70 Engine Swap B5204T4 to B5204T5
- 2988 Views
Last post by RickHaleParker
- 358 Views
Last post by dikidera
- 841 Views
Last post by The_taker
- 11 Replies
- 7050 Views
Last post by cn90
- 1249 Views
