Hi all,
I'm attempting to lubricate the blower motor from my 850, since it was starting to make noise. Thanks to Rob's great video on this procedure, I got it out without a problem, but now I'm stuck. I can't get the fan off the motor - already tried soaking it overnight with penetrant, and tried hammering the spindle out. It started to move just a tad (maybe 1mm), but now is completely stuck. And what's more, the motor seems totally seized - maybe I jarred something?
Anyway, any thoughts on this? Did I completely screw it up now, and need a new one?
Thanks so much!
1997 850 blower fan problems
thedancingfiddle
- Year and Model: 1997 NA 850 wagon
- Year and Model: Many Volvos
- Been thanked: 76 times
Getting the squirrel cage blower off has always been a daunting task for me and I have never successfully done it. What I do is use Triflow oil in a bottle with an extension tube so that I can direct the oil directly to the bearing while the squirrel cage is still on the motor.
Since the whole motor is locked up on you I don't know what to tell you. Perhaps a smack with a hammer on the bottom will free it up. At this point you really don't have anything to lose so you can get pretty aggressive.
- Has thanked: 1611 times
- Been thanked: 4072 times
I got my 1999 fan off with two people ...one holding the fan while I tapped on the shaft with a punch.
thedancingfiddle
Thanks guys. Yeah, I think it may be a lost cause now - I had tried tapping it with a hammer on the shaft (with it resting on the outsides of the fan cage, so the motor was suspended.) Then I tried soaking the shaft in penetrant over night, and got the shaft to move a tiny bit, but now it's stuck, and somewhere in there the motor ceased turning. It's not totally stuck - I can turn the fan, but it's hard, and with much resistance.
Hitting the other end of the shaft, and the back of the motor, has gotten no where.
