1999 S70 One of these head bolts is not like the others.
Brucebo
Year and Model: 850 '96, S70 '99
Has thanked: 3 times
Been thanked: 5 times
Post by Brucebo »
By the way, who is the recommended shop nowadays for rebuilding your Volvo head?
Broken head bolt
Broken head bolt
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Been there, done that. Easy out is your best friend after finding a good, sharp reverse handed drill bit.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Ugh. Sorry to see that.
Check this out regarding rebuilt heads: https://www.matthewsvolvosite.com/forums ... =1&t=69336
Brucebo
Post by Brucebo »
Scuttlebutt on the web is, once the top of the bolt is broken off, tension is removed from the threads, so it should not be too difficult to remove the stub with a reverse drill and/or an Easyout. I currently have the hole filled with Liquid Wrench. I also put an exact diameter transfer punch down in the hole and tapped it with a hammer to put an exactly centered starter hole on top of the stub for the drill. I also plan to put a steel bushing in the well to keep the drill bit centered and protect the sides of well.
E Showell
Post by E Showell »
Transfer punch and bushing both good ideas, but I am here to tell you that a good, sharp reverse threaded drill bit will be your best friend. A good cut followed by an easy out of the proper size and you'll be good to go. Just move deliberately and carefully and you should be fine.
'95 855 auto (sold)
E Showell
Post by E Showell »
Let me guess. Back side of engine, i.e., adjacent to firewall, between cylinders 2 and 3 or 3 and 4?
'95 855 auto (sold)
Brucebo
Post by Brucebo »
Exactly! Must be not too uncommon.
Has thanked: 1610 times
Been thanked: 4069 times
Anything one can do here to prevent this nasty? Maybe getting penetrant down the threads before loosening?
Brucebo
Post by Brucebo »
abscate wrote:Anything one can do here to prevent this nasty? Maybe getting penetrant down the threads before loosening?
How would one do that? Before loosening, the bolt head flange is tight against the top of cylinder head. No way to get to the threads. I suppose someone could design a head bolt with a small cylindrical hollow center shaft to serve as a temporary oil galley, with small radial galleys going out to the threads. To be filled with PB Blaster prior to removal.
You can get penetrating oil to tight threads with...
Time
heat
Reasonable application of shock - rattling the bolt with careful taps
