1998 v70 Service Light Reset 'Tool' ?
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello,
First, does anyone know how to get one of these things cheaper than about $170 USD ?
If not, can anyone get information on the protocol that Volvo uses for communicating with the device (such as the computer) that resets the service light? If so, i will gladly design a reset tool and save 150 dollars for something i really should be buying at a reasonable cost.
I would need the complete protocol, such as any handshaking, etc. My first guess is that the tool uses a simple microcontroller that sends a series of bytes to the computer and that turns the service light off. Microcontrollers today cost between $1 and $5 USD for most types, even more advanced type units. Since that would be 99 percent of the 'tool', the cost should be very low to build one.
But i would need complete information about the communication between the tool and computer.
I would also be willing to hand the finished, tested design to others if they wanted to build one too, or even get someone to build a bunch of them and sell them for $10 USD or something like that to anyone here who wants one.
Thank you :-)
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
Just take the light bulb out of the cluster. Problem solved. It takes 45 minutes the first time, and about 20 minutes any time after that. Probably far less time than it will take to design a switch to turn it off.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I used the bulb removal method as well, but I did it when I had to remove the cluster to replace some burnt out bulbs in the remainder of the cluster.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I allready responded you in a previous post you asked about this.
Vol-fcr with a cable is around 25$ on ebay or amazon.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MrAl
Post by MrAl »
Hello again,
Oh ok, thank you. I must have missed that or forgot as i have been stretching out thin lately with various tasks at home to complete.
I will look for that tool and see if i can find it.
I would take the light out too but i had to mess up the cluster.
Thanks again.
Oh and thanks for the heads up on the SRS light in the other thread too.
MrAl
Post by MrAl »
Hello again,
Ok i checked out the FCR tool and that is not a stand alone tool but requires a PC with a serial port to work it, also with a software download.
I currently do not have a Laptop only a desktop and tablet computers. I would have to pack up my whole PC (box, monitor, keyboard, etc.) and take it outside with me. Im not sure that is a good idea.
It looks like a very interesting tool however. What else can it do?
Any other ideas?
osman
Year and Model: 2002 c70 hardtop
Post by osman »
My cable is a usb and it works just fine with a cracked version of VOL_FCR and a windows xp simulator on windows 8.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Well I guess you could buy the Vol-FCR and hook it up to your computer and then measure the generated signal when sending the "clear service" light command. You may need to power certain pins of the OBDII plug with 12V.
By the way the cracked or demo version of the software won't reset the SRS light. The full version is required.
misha
Post by misha »
MrAl wrote:... What else can it do?...
It have access to every single module in the car including service light reset.If you have motronic 4.4 engine management...you can read engine codes with it.With newer version you will have live data.
@ precopster ...i have cracked version and it reads and clears srs light just fine.Lee have it too and it works with srs light also.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MrAl
Post by MrAl »
Hi,
Mike:
Thanks Mike, i was downloading the 'demo' version, but i have serious doubts if i will get the unit anytime soon as i have other things to purchase right now for the car. Maybe in the future though.
Yes, that would tell me the signals that were being sent. Would be nice to be able to get a copy of the protocol though, as that would be simpler to work with and faster for me to develop a new tool just for the service light. Lucky this isnt a super important issue, just one that i would like to address properly at some point anyway.
Misha:
Well you mention the SRS again, but Mike was talking about the 'Service" light, and that's what i was talking about too now. Will your software setup clear the 'service' light or not?
It still sounds very interesting even if it doesnt, but would be nice if it did. I would probably start with the 'demo' version.
How much does the 'full' version cost?
