I recently purchased a 2002 s60. I'm planning on getting the interior looking like-new.
1. The leather seats have one or two very small holes in the "hide". You can see the filler/cushion.
2. The leather is cracked,dirty and worn.
3. The plastic side paneling on the interior of the door panels has a few holes poked in it. This is the very firm, non-flexible plastic door paneling right behind your calf when you sit down in the driver's seat.
4. The floor mats are really dirty and worn.
I'll update this post with pictures later - the dealership is fixing a "Service Airbag: Urgent" check engine message atm, so I can't get in there to take pics.
Here are my questions:
1a. Should I get a professional to do this work, or should I do it myself?
1b. What's a good price to pay for a pro to do the work?
2a. If I do it myself, can you recommend a leather repair kit (Leather cleaner, patches, gloss, etc)
2b. Should I just consider seat covers? Are there ones that look really nice in the volvo s60?
2c. Can you recommend a door panel "patch kit", if one exists (For the plastic)
3. Recommend carpet/floormat cleaning supplies
4. Recommend interior "maintenance" products for weekend cleaning to keep it looking and smelling great (Shine, gloss, scent, etc)?
2002 s60 Interior restoration (Leather seats and door panel)
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
I have these and they look pretty good. At least better than most seat covers. http://stores.ebay.com/topcar-athens-ca ... 7675.l2563
I am told that if you can find a junker with good leather, you can do a DIY job by carefully pulling the leather off the donor car and put it on yours. I have not done it. May be a tutorial on MVS somewhere.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
V70r carbon
- Year and Model: 2005 v70r
Good questions... no answers ...
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
I'll take a stab at this with my recent experience. It is by no means authoritive.
I got an 03 V70 with a TRASHED interior. Covers wasn't a choice.
I sourced a set of seats from 02 XC and they dropped right in. 4 bolts and I had new seats!! The door bits I could have borrowed if it would have had the Dolby sound package. I also procured the carpets, door sills, center console trim and anything I could that would fit in my car. Yes... It was that bad!
The only problem with the donor is that there was a 4" crack, down to the mesh, in the driver's bottom pad. I found several online options for DIY repair that seemed very doable. I'll post them when I get home.
By the luck of the Junkyard Gods, I passed by a S60 in the yard a day or so later and happen to look inside. The seats were exactly the same as the XC, except for the lack of power on the passenger. No problem though as I was only after the bottoms. I did a bit of hog ring surgery right there and 10 minutes later I had 2 covers and one pad.
That evening I revisited the operating room and in less than 30 min had a new, albeit slightly different shade, seat bottom. I just used the cover as the seat heaters in the XC seats worked great and just wanted it as a spare.
So my take on the question.... If you have a ready supply of donors, a few minutes with a pair of pliers saves you big $$. If you have a special color or stitching (the S60 doesn't match the XC double stitching... but I can live with it for $4.95) you might want to investigate repairs.
I'll post the 2 DIY processes I thought best in a bit.
Cheers!
K "hogged" S
Cheers!
K "hogged" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- Botbasher
The links to those DIY leather repair sites are....
This one supplies the entire kit... Quite expensive and not as many color choices IMHO.
https://scratchwizard.net/automotive/background/paint/
This one is a bit cheaper, you'll supply some of the materials, BUT they mix custom colors to match whatever your base is. Could be more desirable depending on your level of need!!
https://www.rubnrestore.com/leather-repair/
Hope that helps!!
K "repaired" S
Hope that helps!!
K "repaired" S
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I have bolted in better seats (by far the easiest option); swapped seat covers from a junkyard donor -- not a bad option (but significantly more time consuming than a drop in replacement); and purchased new Ellwood Industries leather seat covers and fit those (by far the most expensive option) and the new leather replacement option gives you a brand new looking seat, much better esthetically than the other two options, but probably not worth the cost on an older car unless it is otherwise mint, low mileage, rare collectible, etc., that you plan to run forever. Keep in mind with an '02 we're only a few years away from that sweet spot where certain spare parts are going to become increasingly hard to find and junkyards may afford the only option for keeping cars on the road.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 6 times
I have a 2002 V70 that is in the last stages of being stripped. Beige (or close) interior color. I still have a few plastic pieces, the drivers front door panel, rear seats, a nice headliner and assorted odds and ends. You are welcome to them free of charge. 4-5 hours from Vegas in Los Angles/Orange county area. Front seats gone all ready. Mike
- 8171 Views
Last post by MoVolvos
- 2741 Views
Last post by cmdz
- 904 Views
Last post by SonicAdventure
- 131 Views
Last post by BlackBart
- 579 Views
Last post by obayha
