1998 V70 AWD Turbo - ECM ECU what other models or years fit?
Andrew Vanis
Year and Model: 1999
Been thanked: 11 times
Post by Andrew Vanis »
ECM / ECU / Computer – what other models or years fit? - 1998 V70 awd turbo
Mechanic tells me to look for a replacement to fix a misfiring situation - originally chronicled here - https://www.matthewsvolvosite.com/forums ... =1&t=69082
What models or years can I pull a ECM ECU from that will work as a replacement for my 1998 v70 AWD Turbo?
Thanks,
Andrew
1998 V70 NA (11/97 build date) 230,000mi
BigRed
Year and Model: V70R 1998
Post by BigRed »
If your feeling adventurous, any ECU from a Turbo model with Motronic 4.4. You would need to flash the proper stock firmware.
M44 Wiki
Andrew Vanis
at this point I'm lokingfor lug-and-play
Flashing etc, maybe later but I'd have to learn about it. Now I just want to drive the thing.
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
There won't be plug and play because of immobilizer.
So flashing is absolutely necessary.
If you have questions about Volvo firmware ask me. I may know an answer :)
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Any 98 GLT or AWD will be a direct swap, although you need to pay attention to the air pump if you are not willing to consider the diode trick.
Any 98 T5 ECU will work just fine if you are willing to also swap in T5 (white) injectors at the same time.
There is no immobilizer issue on a US-spec 98.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Ecu which have exactly the same Bosch numbers like yours will be required.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Post by erikv11 »
Just not true for the US cars. My 98 GLT has a T5 ECU, it has been done many, many times.
Maybe this guy is ready to give up and part out the car, offer him $40 for the ECU ... http://albuquerque.craigslist.org/cto/4998210820.html ... or $400 for the car and you will be covered for every nuisance longevity failure over the next 5 years. :D
misha
Post by misha »
And you're saying that you don't have check engine light on with T5 high pressure turbo ecu on GLT which is low pressure turbo?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Yes. The same sensors are used and the correlation of MAF signal is very close. The T5 ECM will have some fuel trims that are 75% of the way to a fault code but I have not seen them set codes unless there was actually something wrong. You have to use high octane fuel since the fueling and timing advance are for an engine with 8.5:1 comp ratio and spark knock becomes much more of an issue with 9:1 CR.
Post by erikv11 »
What jimmy57 said. You can upgrade the turbo to 15g or 16t with the T5 ECU installed (true, I did that), but it is not required you can also just leave the 13g in there. Put in the larger (white) injectors and the fuel trim issue is averted altogether, but as stated it doesn't throw codes for fuel trim either.
