1999 V70XC Headlight and turn signals are intermittent
I believe there was a headlight switch recall on the 1999 models, there was on my T5.
Ignition switch is another possibility if the two fail simultaneously.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The ignition switch can be bought at Rockauto under the name Airtex Wells (LS963) and is actually a genuine Volvo part reboxed. About $18 cheaper.
Turn them on, then try jiggling the key in the ignition, to see if you can generate the fault. That will tip you off to the failure of the ignition switch, electrical part.
This is an easy, 15 minute replacement job - the electrical part of the switch pops off the key part so you don't need new keys or anything crazy like that.
- 1753 Views
- 596 Views
Last post by Shaddiz
- 2689 Views
Last post by SuperHerman
- 2329 Views
Last post by zupta82
- 865 Views
