2000 v70 Still pinging
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
Hi. I used 93 octane, but now that the weather is hot now, I am again experiencing "pinging" when accelerating. I tested the pcv valve and it appears to not be clogged. What would be my next step. I do have 215K miles on the car and burn a quart or so of oil every 3K, but everything seems fine. What would be my next steps for figuring this out or solving the problem?
Thanks,
-Feld
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Quart of oil every 3k is nothing.Quart of oil every 1k is upper limit of oil consumption.What oil viscosity do you use?At 215k it should be time for thicker oil like 10w-40.
What codes are stored in ecu?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1610 times
Been thanked: 4068 times
Is it light pinging only on hard acceleration or does it sound like egg shells breaking?
Probably ok if light.
jblackburn
Year and Model: 1998 S70 T5
Been thanked: 20 times
Post by jblackburn »
Run a top-end cleaner through your motor. Carbon deposits on cylinders/valves can make for all kinds of nasty knock.
'98 S70 T5
2016 Chevy Cruze Premier
misha
Post by misha »
Pinging can be caused when coil pack(s),ignition leads,map sensor begining to fail.Also when it's time for new spark plugs or old one needs to be re-gapped and when there is vacuum leak.
Since these 20v cars don't have a map sensor,i would check remaining stuff from the list.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The top engine is running too hot. Hard to pinpoint the reason, one thing that helps is to remove the plastic cover over the coil packs and try a different gas station. Is the fuel filter clean? I too have it sometimes in the summer, my PCV is clean. I suspect some gas stations don't have proper 93 fuel
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
Second on carbon due to miles and burning oil. Combustion chamber cleaning. Most efficient is steam or water injection.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
famfeld
Post by famfeld »
Oragex,
Once I get to the coils then what. Right now I have the covers to replace the plugs. Should I try a cooler thermostat? Strange thing is that when I got the car it had no heat because thermostat was making car run really cool. It still did ping some originally, but maybe that was not a coincidence. I have since put in a new thermostat to get good heat. I may try putting in a cooler rated one.
-Feld
jblackburn
It shouldn't ping with the current thermostat - it didn't when new. I doubt it is a coil pack either honestly. Ping is a result of pre ignition due to low grade fuel, improper timing, or heat ("hot spots" or wrong heat range spark plugs").
'98 S70 T5
famfeld
Post by famfeld »
I did 2 cans of seafoam, then changed the oil. It seems to have helped. I am going to keep running fuel injection cleaner, since I have had good luck solving other cars' pinging problems in the past this way. So is it fair to assume 93 octane is the only fuel my V70 will run on?
Thanks for all the help
-Feld
