2002 v70 2.4 turbo with TCM issue
Lewis
Year and Model: v70, 2002
Has thanked: 1 time
Post by Lewis »
Hi,
I've had recurring issues with a P0715 code that point to a failing TCM. While that may or may not be the real issue, it seems to be pretty straightforward to get a compatible TCM and swap it out.
But I've seen references to a tool that is necessary to remove the TCM. I'm not sure if that applies to a 2002 V70 or not. If it does, what is this tool and what does it do?
Thanks,
Lewis
sergio
Year and Model: S60 2002
Post by sergio »
The tool is called Volvo tool # 999 5722 and sells for about $ 60 or more.
But you may make one yourself as I did. For less than $ 10, instructions here;
https://www.matthewsvolvosite.com/forums ... 37&t=57066
and good luck
S60 2002 180K miles looks and runs like new (except when sulking)
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Half that price at IPD however not a well made tool from them.
Yes for 1999 and above you always need this tool.
Lewis
Has thanked: 1 time
Post by Lewis »
Thanks, guys! I ended up using the technique here:
http://sweet-sauer.com/2013/08/06/its-all-in-the-box/
which worked out pretty well. I had to move power steering reservoir and radiator overflow, as well as wiper fluid fill neck first, but everything came apart and went back OK.
Ran it thru the gears a few times in the garage with the "new" TCM with no issues, and then a test drive of 5 miles and still no issues. I'll drive it around town for a few weeks before I call it fixed, but I think I've got it!
Lewis
