The CEL went on while driving, so I checked it when I got back figuring it would be a returning code of bank 1 or 2 too rich. I checked the battery with the car running and it was hovering around 16.28 - 16.30. When the fan kicked on, it dropped down to 15.xx.
The alternator was replaced a few years ago with a replacement from FCP.
Any ideas? I know the battery ground cable disconnected from the lug, which is still bolted to the motor (shame on me), but it's been fine for years.
The car has 303k miles on it if it helps point me (or you) in a certain direction. Is there anyway to test the voltage regulator?
Thanks,
Chris
1998 s70 p0563 System voltage high
cjbmustang
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Re-connect that ground immediately if it's not too late for alternator or battery.
Of course...it could be just voltage regulator which failed,but the detail about ground wire is pointing to bad or no ground.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cjbmustang
it's been off for like 5-8 years...doubt it would randomly start causing me problems now. For ha ha's I will ground it. It sounds like the voltage regulator to me...just looking for opinions
- misha
With alternator output like you have...you're lucky that your ecu(s) are not frayed.Don't drive a car until you solve charging problem or all of modules in the car will be toast.
I would try with changing voltage regulator first.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cjbmustang
Won't the car just go into limp mode?
- misha
Only specific codes can put a car into limp mode.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cjbmustang
Looking at them they are like $140 and a whole new alternator is like $180. Usually a new voltage regulator is $20-$40.
Are they made from unobtanium?
- misha
A good car electrician can rebuild your old voltage regulator.Btw...that is the only part of alternator that can go bad.Most of the time.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 5638 Views
Last post by hans747
- 576 Views
Last post by wizechatmgr
- 925 Views
Last post by Vancethevolvo
- 3317 Views
Last post by rguzz
- 955 Views
Last post by martin calva
