going to drain & fill the bevel gear and rear diff. the rear diff calls for straight 80w, seems to be hard to find at the local parts store. can i use the same 75/90 as the bevel gear? plan to use high quality syn oil.
on the ps, calls for pentosin, is there a readily available equivalent? also, i thought i read somewhere that the pentosin fluid is green in color. checking mine, the color seems to be typical ps fluid yellowish color.
2005 xc70 question on fluids
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
mrscullini
thanks. how about the bevel gear. is mobil 1 75/90 ok? or is there a preferred oem?vtl wrote:Don't use 75w90, buy Volvo OE oil for rear diff, it is slightly over $20 for 1 liter.
Pentosin CHF202. It is green, but color fades over time.
- 1387 Views
- 19 Replies
- 2841 Views
Last post by mecheng
- 30 Replies
- 4880 Views
Last post by polskamafia mjl
- 4000 Views
Last post by MadeInJapan
- 3062 Views
Last post by Cees Klumper
