1997 850 wagon disappearing coolant
Tobers
- Year and Model: 850 wagon, 1997
My daughter's 850 loses about a reservoir of coolant every couple of weeks. I've looked everywhere; no trace. So today I let it run for 30 minutes in my driveway. The fan was running. It was at full operating temperature. No sign of coolant anywhere. So I drove it a few miles, and watched it some more. Not once could I find a drop. I changed the water pump less than 5k ago, so I doubt that's it, and I'm guessing if it leaked there it would drip out the bottom somewhere anyway. It runs great. I tried to get a coolant system pressure set up from OReilly's, but it didn't fit the Volvo. Next steps? Thanks. Rick
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Any white smoke in the exhaust? Have you checked compression? Abnormalities in these might suggest you're burning coolant and sending it out the tailpipe, hence why you wouldn't see it dripping.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
A compression check may or may not tell you anything. The Volvo "White block" design is known to pressurize the cooling system if there are small breaches in the head gasket. Search this forum and you will find references to small amounts of coolant being "used". The sneaky part is, that it won't show much on a compression test. A block test kit may reveal exhaust gas entering the coolant system: it uses a reactive liquid, and a gas-permeable barrier in a beaker you place on your coolant reservoir. Some owner's have driven their cars for a year, minding their coolant level, before having to perform repairs. Also, have you checked for leakage in the heater plumbing? it could be inside your car, and not dripping outside.
Anybody else know where other "sneaky leaks" might be?
Current Volvos:
Tobers
I replaced my heater core 12 months ago. I doubt that's it. No white smoke out of exhaust that I'm aware of. But I am throwing a p0303 code. I changed my distributor cap and rotor (they were bad), but I'm stilling throwing it. Also, occasionally at cold start it shutters (I know my SAS/airpump aren't working right, if that matters). I think those can be related to a head gasket failure. Obviously I'm hoping for the best, and looking for the best way to determine what's going on. thanks! Rick
- Been thanked: 4064 times
Take a good look at those plugs when you pull them. If they all look normal don't sweat the coolant use
- Has thanked: 311 times
- Been thanked: 817 times
A reservoir of coolant every few weeks is a lot, I would not ignore it, no matter what the plugs look like I would get to the bottom of it. Smell the exhaust, is it sweet? Are the carpets dry in front (even though you recently changed the core)?
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I had the same problem and was loosing coolant at about the same rate as you. I took me a while to find, but it ended up being the small hose that dumps coolant into the reservoir. The leak was small enough that no drops ever hit the ground.
That hose connection at the reservoir seems to be troublesome. When I got my 850 a few weeks ago, it leaked at the same spot.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
Yeah i was going to say that if the leak was small the water could evaporate when it hits the engine block so you'd never see it. Depends on how bad the leak is though.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I have the coolant system pressure cap needed for testing the system if you live anywhere near Salisbury, N.C., as I see you are in NC.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- 1838 Views
Last post by FLXC90
- 565 Views
- 1583 Views
Last post by Darkskies65
- 1205 Views
Last post by misha
- 544 Views
Last post by JaydieselV70R
