2002 V70 T5 Sunroof/alarm9452709 D P2 Alarm module Topic is solved
Lou Rosenbaum
Post by Lou Rosenbaum »
The roof works when it wants to... then will take multiple pushes of the button to close. Also have an intermittent "Alarm System Maintenance" light. Looking at other responses to similar issues, my roof issues may be related to the alarm system module. Can anyone point me to the appropriate part of the alarm system and were it's located.
db130
Year and Model: 2002 V70 T5
Post by db130 »
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
Lou Rosenbaum
Lou Rosenbaum wrote:The roof works when it wants to... then will take multiple pushes of the button to close. Also have an intermittent "Alarm System Maintenance" light. Looking at other responses to similar issues, my roof issues may be related to the alarm system module. Can anyone point me to the appropriate part of the alarm system and were it's located.
6/8/15
Job is done, great tutorial thank you . Did the 3x lock/unlock every thing works a o k . Fyi the siren module has gone up a tad since the tutorial $230 in 2015 and Volvo wanted $600 installed.
Way less than an hour.
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
Paid 70 for mine, ebay.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Lou Rosenbaum
Lou Rosenbaum
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
draser wrote:Paid 70 for mine, ebay.
It will fail too. Battery is above PCB, not sealed.
Lou Rosenbaum
not sure why anybody would buy a used part that's biggest problem is leaky batteries
draser
Post by draser »
I actually cut it open, after testing it, battery and leads were toast. Cleaned board of any traces of acid then soldered a resistor from battery positive to pin 2 I believe, which is connector positive. JB welded back together, this is lifetime.
vtl
Post by vtl »
draser, does this drain your main battery.
I replaced a battery and sealed it in polyethylene. This will last for another 10 years only, but oh well, $12 only :)
