2004 S80 T6 Clunk sound when shift to D and R
The S80 has 124k miles. Recently when shifting into D the front drivers side wheel makes a "clunking" sound. Shifting into R and D the same clunk is heard. Seems to be coming from behind the front drivers side wheel. Also the clunk can be heard when letting off the gas and pushing the gas pedal. I have a dealer appt. on Friday. Any guess what this could be. Probably something in the drive axle
but hopefully a motor mount.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
First thought was the torque mount - I don't know where it is on the S80, but have you checked it If you have one?
My old S70 made that noise when one of the bushings was rotted out.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
THAI UNG
- Year and Model: 2007 V70 2.5T
- Been thanked: 4 times
There is another possibility beside upper torque mount bushing and lower engine mount behind the engine that gone bad,I used to have the same problem once in while when it happen I just pop the front wheel center caps and tighten up the 14mm bolts that hold the driveshaft to the wheel hub because these bolts do get loose and the clunking noise disappear . Hope this helps...
Dealer diagnosis: "Install glue to the axle spline". It will take an hour and then the car needs to sit for 6 hours for the glue to dry.
So now I need the opinions on this procedure. I have been reading a little about this and I guess it is fairly common, but it does make removing the axle at a later date a PITA!!!!!
precopster
- Year and Model: Lots
- Been thanked: 128 times
Yep and ask them to foot the bill for any documented extra time on front end repairs due to the glue.
The dealer is the last place I would have this fixed. Because of possible litigation for non standard repairs their creativity score is a zero. If glue fixes it a nicely machined spacer would have done it too, however dealers are not allowed to do this.
- 2305 Views
Last post by MadeInJapan
- 1220 Views
- 2544 Views
Last post by AVOIT17
- 1702 Views
Last post by Legofan
- 689 Views
Last post by carguy124
