2004 S60 Exhaust cam won't come out
billwann
- Year and Model: s60 2004
Help! I'm doing a cylinder head job on my son's S60. I've got the upper portion of the head off and the intake cam lifted right out. For some reason the exhaust cam won't budge. I don't want to try to force it so I stopped until I got some advice on the topic. Any ideas?
precopster
- Year and Model: Lots
- Been thanked: 128 times
On the rear end of the cam you should find a 6mm thread tapped. Place a bolt of good length say 4 inches into that thread.
You can now connect a rope or cable from the front cam pulley to the bolt.
A short sharp tap upwards on the bolt with a mallet and the same on the front cam pulley should dislodge the cam seal. Then just pull up evenly on the cable or rope. Try to keep the cam very horizontal during the lifting because the cam guides can be broken by angling the cam.
- 613 Views
Last post by nelaco
- 315 Views
Last post by jonesg
- 14 Replies
- 2470 Views
- 3027 Views
Last post by mouseskowitz
- 2007 Views
Last post by joedrt77
