I finally got around to tracing out why my headlight is dim/ position light half bright, one headlight on with approach lights etc.
I found a short wire added, badly, from the position light + to the + of the low beam H11 in the drivers side lamp housing. Removed this and corrected wiring in the headlamp assembly back to normal stock. Now I have no power coming to the drivers low beam, hence the reason someone hacked up the wiring and added the jumper.
Traced back as far as I can, 20a fuses in the underhood fuse box are good, I have to assume the 40 A fuse is good, as it feeds the 20a. Pass side working fine, but no power to the Blue White wire at the headlamp plug. I can't see any other junction points, it is shown coming from B7 on the CEM.
I looked, but can't seem to find any info...Is there a replaceable relay, or is the relay integral in the CEM and that's that?
Only similar post I found was this one.. https://www.matthewsvolvosite.com/forums ... =9&t=51261 and he was buying a CEM.
Any help appreciated
2005 xc70 drivers low beam inop
2005 XC70, Dumb luck bargain.
2001 V70 XC, The learning experience.
2007 Frontier Crew Cab, The practical vehicle
1966 Datsun 2000 Roadster, Happiness on 4 wheels
1964 Datsun 1500 Roadster, Pile of parts, hibernating
This might be something, corrosion issues in the main connector.
Link downloads PDF of Volvo repair bulletin
http://www.google.com/url?sa=t&rct=j&q= ... 0622,d.eXY
- 516 Views
Last post by hu5ker555
- 1872 Views
Last post by S60T5SE
- 622 Views
Last post by osteovolvo
- 664 Views
Last post by drfoster
- 1394 Views
Last post by RickHaleParker
