Hello,
I am trying to diagnose a clunk in my right rear wheel. I was told that I have a stabilizer link on both sides of the rear suspension. For some reason I cannot locate these links.
Any help would be great.
Thanks so much.
2004 Volvo V70 Rear Stabilizer Link
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
To check for the link just slide a hand under the car from the rear - without jacking it - and shake the end links to feel for play. But I have play on my left side and it makes no noise.
I had such annoying clunk at the same rear right place. It was the hand brake cable that wasn't properly secured. The fuel pipe that goes to the tank also can hit the wheel arch and make noise. Finally, the brake shoes are known to delaminate and may became loose inside the drum but it's less likely to be the culprit.
- rearsusp.jpg (27.67 KiB) Viewed 1914 times
- 15 Replies
- 5471 Views
Last post by Keithnysm
- 1276 Views
Last post by jimmy57
- 47 Replies
- 7832 Views
Last post by jantt
- 10193 Views
Last post by SuperHerman
- 1411 Views
Last post by hu5ker555
