Title says it all. Rear wiper blade stuck halfway up the back window. The wiper switch appears to have no effect, but I can hear the pump motor working when I use the "clean" function, so I doubt it is a switch problem. Car has nearly 290k miles. It is likely a failed wiper motor at this mileage?
Any thoughts?
'98 V70 5 spd non-turbo -- Rear wiper stopped mid-travel
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4063 times
Search for the thread on broken wires in the right hinge. Ill put 666:1 odds on broken wire over motor.
Bumped thread with pix to top of forum
link here
https://www.matthewsvolvosite.com/forums ... =1&t=60350
link here
- Has thanked: 311 times
- Been thanked: 817 times
I had this happen a bout 2 weeks ago. Assuming it was broken wires (good call, Steve) I first took a look at the wiper from the outside and noticed the plastic sleeve around the shaft was split open. Probably had been for some time so simple corrosion seemed plausible ... sprayed in some good penetrant and the motor started working again. Sealed it up with self-fusing silicone tape and its been fine through the recent rains. I'm sure wire fatigue is coming soon, but I'll sit tight until it shows up.
- E Showell
Thanks, Erik. I'll see what a shot of PB Blaster accomplishes, if anything.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
As Erik noted, the plastic sleeve around the wiper spindle was cracked. I've got three applications of PB Blaster on it so far and no joy, but I'll give the PB Blaster a little more time to work it's magic.
I did not get into the hinge wiring because it all looks very neatly placed, wrapped and protected inside a little plastic cover and loom.
If the PB doesn't cure it, I guess it'll be time to dig into the wiring.
The S70 got new-to-me door panels this weekend. They are puckered, but way cleaner than what they replaced, plus a little time with the "Magic Eraser" -- my new favorite detailing invention -- and they look almost new. In fact, they came out so well (and the old ones were really disgusting) that my daughter no longer refers to the car as the "diseases mobile".
'95 855 auto (sold)
'95 855 auto (sold)
It does, doesn't it?? And underneath that nice loom lies a bunch of broken wires...I did not get into the hinge wiring because it all looks very neatly placed, wrapped and protected inside a little plastic cover and loom.
Hope the PB works, but if not, yeah,,you have to cut open the sheath to find the problem. I had some nice pics in my thread which I can't find....
I did have to help the motor to move by hand to free it up. And in fact I was able to get the wiper to limp along it s path by manual assist before I went to the penetrating oil.
- E Showell
Ding, ding, ding -- we have a winner. Thanks Erik. Copious amounts of PB and a little manual assist have the rear wiper functioning again. The plastic cap protecting the shaft was split in two places. The PB Blaster actually flushed out a bunch of crap onto the paper towels I used to keep it from saturating everything in sight.
'95 855 auto (sold)
'95 855 auto (sold)
If you haven't experienced the marvel of self-fusing silicone tape, I suggest you check it out. This is a perfect application for it, it will create a nice black surface that seals up the shaft again.
- E Showell
Where can I get some? Local Lowes/Home Depot?
'95 855 auto (sold)
'95 855 auto (sold)
- 713 Views
- 3173 Views
Last post by cajunxchange
- 2215 Views
Last post by Sixthandredline
- 694 Views
Last post by E Showell
- 20 Replies
- 6944 Views
Last post by FireFox31
