1998 s90 wont turnover in hot weather
Volvo security system seems to malfunction when weather is hot. I start car windows won't go down and I cant get car out of park. I need to turn car off and restart car then I'm able to put windows down and shift into drive...most of the time this works. However I tried this yesterday...I started car couldn't put windows down or shift, shut car off and now it will not start. is it the security system or maybe something else. I bought this car 2 years ago from someone and I'm not sure how the security systems works and if its related. Can someone please give me some advise?
precopster
- Year and Model: Lots
- Been thanked: 128 times
The electrical portion of the ignition switch is shared with the 850 and can have worn contacts.
All sorts of electrical ailments occur when they're playing up. Try jiggling the ignition switch to a new position when it's playing up and see if this helps.
harryhendo
- Year and Model: 940, 855, S70, V70
Sounds like the shift lock relay needs to be replaced. This is a common failure point on the RWD cars. I can't recall where it is on the S90, but on the 960 it is behind the ashtray. It should be listed in the owner's manual.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
'94 855 (manual!)
'02 V70
Ethan Rode
- Year and Model: 960 1996
Assuming that you don't have an aftermarket security system, it sounds like the electrical portion of the ignition switch, like Mike said.
- 17 Replies
- 444 Views
Last post by Krons
- 48 Replies
- 10829 Views
Last post by bmdubya1198
- 695 Views
Last post by MoVolvos
- 790 Views
Last post by shevolvo45
- 11 Replies
- 2268 Views
Last post by ashlee2319
