I'm having trouble finding a coolant leak in my V70. If I fill the bottle, the low coolant light will come on a week later. Sometimes, though, it'll be on the next time I start it, even on the same day.
Then as I'm driving it, the low coolant light will go off after a bit. It might come on again later. That kind of varies.
Also, whenever I fill it, it seems like coolant level is at or just below the bottom of the bottle. I tried waiting a week, once inwaited two weeks after he light went on, and it still seemed the level was the same. Thinking it was the bottle, I checked it and hoses going to and from the it, but I don't see a leak anywhere.
Any ideas? Car runs great.
1999 V70 Turbo Mystery Coolant Leak
PapaHepcat
- Year and Model: v70 1999 XC
Current car:
1999 v70 xc Silver, 170k miles
Non Volvo cars:
1991 Ford F-350, 80k(180k?) miles
2004 Toyota Sienna, 124k miles
Non Volvo cars:
PapaHepcat
I'm tempted to just pull the low coolant sensor and leave it.
Current car:
Non Volvo cars:
Non Volvo cars:
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Have you been using defroster in the morning? Any coolant smell in car?-heater core common.
Any clean streaks where coolant may be escaping from a pin-holed or split hose or tube?
Take a close look at the underside of the upper radiator hose nipple, common cracking area.
What is the age/condition of your overflow bottle/radiator cap and its seal?
By design, coolant is siphoned from the bottle, not direct-level, so once it is below the bottle bottom, who knows how much you've lost. try filling it, running the motor to operating temp, then topping off, let it cool and rest, try again. May take a couple cycles to fill.
Also, because it is a white-block Volvo, have a compression gas test done on your coolant system. NAPA sells them, and some parts stores loan them out. Use to rule out head gasket.
Current Volvos:
