2001 S40 Sunroof leak
waynepearson
- Year and Model: Volvo S40 2001
Rain leaking around Sunroof. Comes in faster than drain hole can empty it from metal tray beneath glass. Any known fixes. I would assume it is from the gasket shrinking over 14 years.
mf70
- Year and Model: V50 2006
- Been thanked: 2 times
#1: Test drain capacity. They "silt up" over time, with a restricted opening on the lower end of the "A" pillar drains.
#2: How is the opening in the roof? On my car, a PO tried to cure the sunroof leak by smearing silicone sealant around, creating an irregular surface that leaked much worse.
#3: Replace the flexible gasket. I believe it's a standard repair part.
- SuperHerman
- Been thanked: 207 times
Tons of stuff on this. Take off pillar cover, cut tube and run a hard line up and down. Add a clear plastic tube with ID about same as factory tube OD. Use some silicon to seal up. Take off large plastic cover that is over wipers and snip the ends of the elbows. I found this was way easier than removing the elbows, especially on passenger side.
I would remove all silicon that you found added.
- 3162 Views
Last post by Reinie
- 1002 Views
- 3927 Views
Last post by RickHaleParker
- 413 Views
Last post by ZionXIX
- 2098 Views
Last post by jonesg
