2004 XC70 A/C Quits Cooling
AC will occasionally (once or twice per week) not cool if the car was turned off with AC running. Pulling fuse for ECM resets the problem. The AC doesn't fail while car is running, or when AC was turned off prior to turning the car off. Any ideas?
- Been thanked: 4064 times
That's an odd one. It does sound like the control unit needs rebooting. There isn't much you can do without software on P2s, though.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
If you have (access to) a VIDA/DiCE setup, you want to look for CCM-related or other modules' COMM Fault codes that may cause the CCM to get kicked out of line.
Also, look for ripple in your supply voltage to the CCM (with the engine running), the problem could be simply noise (EMI), I am thinking a bad main filter cap, or the alt, or simply a broken/loose ground somewhere...
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
That could be, too.
But I strongly recommend reading the car for codes as a less costly approach before your start throwing parts at her (unless you have an 'inventory' car in your garage to borrow parts from...
2015 BMW 335i
2015 BMW 335i
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Just to make sure, the gap at the A/C clutch is withing the specs?
