2005 S80 Radiator fan always runs on high.
Silver_S80
- Year and Model: 2005 S80
About a month ago I noticed that my 2 speed cooling fan is always running. Even when I first start the car. And it's always running on high speed. Any ideas on what might be causing this?
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
If you have any codes on your car than scan it and see what it has, if not it probably will be the coolant temperature sensor or it will be the fan and the fan module wich are mounted as one piece and are well known for failing.
06_CAreaper
- Year and Model: S80 2006
Start small, refill your ac. Spend $50 for a big can and fill it. That was my issue with my 06.
Earn_est_89
- Year and Model: Volvo s80 2006
hey I'm having the same problem with my 05 S80 my AC doesn't work and the radiator fan is always on max like the car is overheating but it's not...did recharging the AC work for you?? just want to know
- 1147 Views
Last post by Earn_est_89
- 935 Views
Last post by Ejbdunes
- 5699 Views
Last post by oragex
- 1383 Views
- 1078 Views
Last post by BryonTheCanadian
