95 T-5R Accelerator Pedal/Cruise Control
Euro_Hobbs
Year and Model: 1995 850 T-5R
Post by Euro_Hobbs »
So in the quest to fix my cruise control I found the servo arm disconnected from my gas pedal and the connector completely missing...I ordered a new piece and screw but for the life of my I cannot figure out how to connect it to the back of the pedal...any one have an idea how this is setup? Apologies as I am typing this from my phone since my Internet is down. See attached pics...
Current Car:
Cream Yellow 850 T-5R w/230k and counting!
Has thanked: 2198 times
Been thanked: 1851 times
Looking at Vida, it is not clear, but I would suggest the slotted shaft goes through the top of the pedal where it looks like a nut is from your picture.
The ball socket end should clip into the end of the shaft for the cruise control that should, I believe be just above it.
The picture I have for both auto and manual shows the bolt going through the hole in the middle of the assembly and I'm guessing is a stop screw or adjustment of some sort. The Vida picture shows the screw coming through from the back as we look at your picture.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 275 times
Been thanked: 84 times
Post by hausmeister »
They don't show the complete assembly, but maybe you can piece it together from this:
http://www.volvopartswebstore.com/showA ... evel=11059
I can take some pictures If you like (as I have the same model), but you'd have to wait until probably the weekend.
850 T5-R '95 auto Image
Euro_Hobbs
Sorry for the delay, if you could get some pics that would be great but no rush! I have it together per what I could make of a part diagram I found and it seems to be working, which is good, I just want to make sure I have it absolutely correct.
Current Car:
