1996 850 front right side sits too low
kenski65
Year and Model: 850 1996
Post by kenski65 »
I recently changed the front passenger side brake pads and rotor. Now it sits too low. Jacked it up again to take look sat her back down and it looked fine.drove around block and i guess the shock deflated again. can i adjust the shock? any help appreciated
Has thanked: 2200 times
Been thanked: 1852 times
Sounds more like something has bent or broken. For starters, jack that side back up and check if the coil he coil spring has broken. Check carefully particularly at the bottom and top of the coils. Anther possibility is your top or bottom spring mount has started to fail. Top is most likely. Put a wrench on the top nut of the shock in the engine bay (car on the ground) and gently try to turn the nut. If it turns easily, your top spring seat is failing and time to change ASAP before the hock punches through your hood!
