Hi
I had an engine shampoo done recently and right afterwards, the car was running very rough especially at idle and the check engine light came on.
I've ad 3 coils replaced (per misfiring codes) and the car now idles well but seems a bit rough still while driving. The check engine light has not come back on.
The car has 165,000 kilometres. And I've been advised that new spark plugs may solve the issue - however - I've also been told that the spark plugs would not have been affected during the engine cleaning. The sparks plus were last replaced at 97,000 kilometers.
Any ideas.
2004 XC70 Running Rough after Engine Shampoo
- Has thanked: 2856 times
- Been thanked: 1332 times
Replace spark plugs.
precopster
- Year and Model: Lots
- Been thanked: 128 times
As above ^^ 70, 000kms is a ridiculous amount of mileage on plugs unless they're platinum.
Down in the spark plug wells the ignition coil rubber boots will have moisture on them. This is where the misfires are occurring after an engine steam clean or pressure wash.
Blow the area out with compressed air if handy or just rags and remove the rubber boots from each coil pack and dry thoroughly.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, there might have been humidity trapped inside the plugs hole. Remov and inspect the plugs, let dry the ignition coils, disconnect and dry the coils electrical connectors.
- 781 Views
Last post by vtl
- 11 Replies
- 1863 Views
Last post by Craigd2599
- 1360 Views
Last post by Gymbo
- 1227 Views
Last post by Chuck W
- 12 Replies
- 2734 Views
