Just scored door locks for front passenger and driver side (and a driver side master controller switch for the door) at Harry's U- Pull It in West Hazelton, Pa. Now the fun begins. Formerly, the driver's door would not open from the inside and the passenger door would not open from the outside. Now, both open fine, but I cannot get the car to lock with the key (and the key fob remote is long gone). I suspect some mounting nuance with the driver side door handle that I am missing. The key turning in the lock feels "mushy" for want of a better descriptive -- like it is being turned through pudding.
Also, the master controller switch (or maybe the locks) is exhibiting the following quirk. If I use the global lock function, the buttons go down on all doors, but immediately pop back so the car will not stay locked. Edit -- Curiously, the master controller switch seems to function fine this morning.
Any thoughts?
'98 V70 -- Fun With Door Locks
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi there ES,
Well i cant help much, but if you are missing the entire outside handle that could make a difference in the feel of the key turn because there is a control rod that connects between the handle and the rest of the locking guts, which includes other control rods, pivot points, etc.
I only have guesses from here.
- Year and Model: Many Volvos
- Been thanked: 76 times
Typically when the locks will engage and then quickly unlock themselves again it is a bad microswitch in the latch. Another common failure point is the wire loom at the tailgate hinge. It can be any lock that will cause that phenomenon.
- E Showell
All sorted and working as intended thanks to my brother.
'95 855 auto (sold)
'95 855 auto (sold)
- MrAl
Hi,Ozark Lee wrote:Typically when the locks will engage and then quickly unlock themselves again it is a bad microswitch in the latch. Another common failure point is the wire loom at the tailgate hinge. It can be any lock that will cause that phenomenon.
That could be what is bugging my passenger side door lock then, which opens but then quickly locks again when pressing the drivers side switch for 'all' doors to unlock.
I hope it is not too hard to get the door panel off and then back on again after any repair.
It is not difficult but 99 times out of 100 the mounts for the panel clips actually come unglued in the process. I would buy a full set of panel clips (including the panel clips for the mirror cover) before you even start and be prepared to re-glue the mounts. The 70 series panels are also bad about coming unglued between the panel and the door pocket.MrAl wrote:I hope it is not too hard to get the door panel off and then back on again after any repair.
I think Robert has a video showing what happens and what he did to fix it. I have tried various adhesives and had mixed results. Hot glue has seemed to be as easy and effective as anything for me.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Evan
I have the key fob from my '98 if you are interested.
Shane
Glad everything worked out on the latches.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- 692 Views
Last post by BEJinFbk
- 1850 Views
- 3079 Views
Last post by fastgroceries
- 944 Views
- 673 Views
