1996 850 - How to fix gas tank lid locking mechanism
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Hey!
Since I bought my "new" 850, a 1996 T5, the projects and small-to-medium issues have piled on little by little, and I try to take them on one by one... Today, the problem of the "door", "hatch", lid, whatever, that you open before screwing out the filler cap not locking along with the other doors.
Some of you might not have the locking mechanism at all - apparently it was an option on US cars, but all the 850s I've seen over here has this. So - how to remove and fix the lid locking mechanism:
1: Remove trim/interior panel on passenger side of trunk area. What you need to access is the area behind the wheel well, where there's a covered opening in the panel above the vent. Take off the soundproofing cover, if it's still there.
2: Remove this screw:
and the clip holding the emergency opening wire. Don't worry, nothing's falling down anywhere.
3: Remove these 2 screws - they're all T15 or T20, iirc:
Once all 3 screws and the clip are removed, pull out the entire locking mechanism. Remove the electrical connection.
Once you've got the whole thing out, it's much easier to see what the issue might be. It's a simple setup, so usually, it just needs some good blobs of litium grease and some WD-40 to the motor.
There are 5 screws on the assembly. Take off the 2 on the "cover" first, and then open the mechanism by removing the 3 remaining screws, which are T10s. Open the mechanism up. You'll see this:
Pretty basic stuff. Grease everything if all is working, replace motor if you must, etc.
Putting everything back together is a simple reversal of the steps.
When you're putting this back in the car, connect power and check functionality before anything else. Then, fix the interior screw first, leaving some slack for movement. Then, find the two exterior screws, and line the locking mechanism up by putting the screws back in. You can aim the screws at the holes, and stuff's tight enough in there for the screws to reach in w/o the assembly disappearing.
- S
[Sold] '97 S70 T5
dosbricks
Been thanked: 4 times
Post by dosbricks »
Nice writeup. Nice to have a contributor from one of the countries I've always most wanted to visit.
Sommerfeldt
Thank you, sir!
Come on over - we're friendly, for the most part. But beef up your beer budget! It's expensive. :D
- G
[Sold] '97 S70 T5
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If you didn't cleaned black dirt marks from little brushes on the rotor it will get stuck again.
Been there:
https://www.matthewsvolvosite.com/forums ... =1&t=31961
:wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Mine is the 1998 v70 and is similar, although i am not sure about the two external screws...i'd have to check.
Yes nice writeup, thanks.
Sommerfeldt
misha wrote:If you didn't cleaned black dirt marks from little brushes on the rotor it will get stuck again.
Been there:
:wink:
Yup - also, if you're not into fiddling around inside the tiny motor, a replacement is about $2 for this kind of thing. Mine is stamped "Made in China", so I'm thinking it's not exactly a specialty item. :D
I saw that post of yours, and opened the motor up, but mine didn't have the black stuff on the brushes, so I closed it all up, greased everything and it seems to be working like a charm now. :)
- S
[Sold] '97 S70 T5
